Activate HW Interrupt in W5500
RE: Activate HW Interrupt in W5500
Hardware Interrupt Pin of W5500 is a falling edge. If an interrupt occurs in HIGH state, it is converted to LOW, and it is converted to HIGH when you clear the interrupt.
RE: RE: Activate HW Interrupt in W5500
by murseloguzandic ·
I got it how it works but interrupt pin stays at high. I want to get hw interrupt for receive moment at UDP…
I’m not sure this init is true which is showing below.
To generate an interrupt in the socket’s recv timing, masking is required in the sn_imr and simr registers.
If udp socket is socket 0, set SIMR (0x01).
This is correct masking to get the recv interrupt.
I’m using like this.
Still no falling signal occurs.
Should I clear or reset interrupts somewhere in my loop?
by Mert Gulsoy ·
Here how I use it:
And I clean the Sn_IR like:
Although I have a hardware problem, I still can see the interrupt pin and related interrupts are working.
My hardware problem is possibly copper pour between w5500 lines.
