Link problems with two new WIZwiki-W7500P dev boards !
RE: Link problems with two new WIZwiki-W7500P dev boards !
by lawrence WIZnet ·
Hi, @crystalset
Thank you for reporting about wizwiki-w7500p working.
Before checking the problem, I would like to know some information.
did you get the test .din file from wizwiki site?
https://wizwiki.net/wiki/doku.php/products:wizwiki_w7500p:getting_started:write_firmware#dokuwiki__top
And could you copy the whole serial output?
Seems you have two cases.
one is RJ45 led works but does not working in software.
second, RJ45 does not working hardwarely.
am I right?
by crystalset ·
Hi lawrence,
Yes - I downloaded the latest binary from the website and installed on both dev boards.
Here are some examples of the debug:
Firmware never detects link even though link LED is On.
by crystalset ·
Hi lawrence,
Please let me know if there are other things I can try to debug the issues with these dev boards.
Do you have any other binaries I can try to test the hardware?
If anyone else has seen this issue before let me know your experience.
Regards,
Dan.
RE: RE: Link problems with two new WIZwiki-W7500P dev boards !
by crystalset ·
Could someone from the Wiznet team please follow up on what Lawrence started as he hasn’t responded for 4 days.
Many thanks,
Dan.
hi, @crystalset
Sorry for the late.
I could not find the original code for the example .bin
Could you try the below code?
And I would like to check AZTOE example for phy link.
Please go to below directory and choose any example
…/W7500P_FW/Projects/Peripheral_Examples/WZTOE
I hope you have IAR or Keil IDE.
Or not, please let me know I will guide you how to install and set up for ide configuration.
thank you
and sorry again for the late.
by crystalset ·
Hi lawrence,
Thank you for getting back to me.
I have compiled the loopback example and installed on both boards.
Board#1 now works correctly:
I also compiled the WZTOE_WebServer project which also worked correctly on board#1.
Board#2 still will not detect the link and the RJ45 Link and Act LEDs do not turn on:
I now think there must be a hardware fault with board#2 because the LEDs are not showing a link and the firmware is confirming this.
What are your thoughts as to the fault ?
Should I return the board to my supplier ?
Regards,
Dan.
hi, @crystalset
I will ask this issue to hardware engineer.
Then reply it asap.
Sorry for your wait.
thank you
hi @crystalset
could you share where you bought it?
If you did not buy wiznet e-sales,
you should contact the market you bought wizwiki-w7500p and notice them the problem.
thank you
by crystalset ·
Hi lawrence,
It was purchased from a distributor in the UK shown below.
Enrgtech LTD
Unit 16 Holroyd Business Center,
Carrbottom Road,
BD5 9BP,
United Kingdom.
I will contact them and request a replacement board.
Regards,
Dan.
by hanbitmicro ·
I think I have same problem of W7500P chip. It’s hardware fault.
I have bought 100 units W7500P S2E rpre programmed at Digikey.
But still 10 test boards I have made wasn’t working. No link is been done.
if you send your schematic file to the below email, we can review it.
lawrence@wiznet.io
