W5500 returning data byte zero always
RE: W5500 returning data byte zero always
I think you are doing a write operation, not a read operation.
If you only want to read 1byte of version register, this value is 00 39 00 00.
Change the value and try again.
RE: RE: W5500 returning data byte zero always
by Elie Assaf ·
Hello Kim
Thanks for your reply.
In fact, this 01 byte corresponds to the Control byte, for which the 2 LSBs are the OM(VDM or FDM), and not the R/W bit. Anyway, I tried to do it with VDM (OM=0), and got the same result:
by Elie Assaf ·
I still don’t have any interpretation.
I tried all R/Ws on all registers, FDM and VDM, and I never have any data. I’m not sure the chip is interpreting well my control.
Anyway, I noticed now that on the MISO line, at the end of a test, I see some flipping, that is not continuous, of a frequency of 25MHz, before the line settles from 0 to 1.
Also, in VDM, I’m seeing that the chip resends the 010203 bytes on MISO after each 4 data bytes. Does this signify
anything?
These screenshots show the toggling at the end of a test
The value mean a per-phase byte numbering and does not affect the system.
01 : Address phase(high -Address )
02 :Address phase( low - address)
03 : control phase
Isn’t the MISO line connected elsewhere?
It’s also hard for me to figure out what the cause…
I will try to fine the cause,too
by Elie Assaf ·
I see, we suggested what you said.
I don’t know about the MISO, the W5500 is implemented on a board with other components.
We suggested it might be a clock issue, maybe caused by the external 25MHz clock, affecting the registers.
I stopped working on W5500 now and bought a W6100 and started working on it.
Does the same problem appear on the W6100?
by Elie Assaf ·
No. W6100 is working perfectly, except that I can’t write on the MSSR, that’s the only register that’s unwritable, and I still don’t know why.
If you have any idea it would be great:
