TCP Client not connecting
RE: TCP Client not connecting
I don’t understand your environment well.
Is the w6100 a TCP server?
First of all, TCP Client’s port is 0 when viewed through wireshark.
This seems to be a problem.
RE: RE: TCP Client not connecting
by mateusz ·
I know that my code contains a lot of abstraction. Sorry about that.
W6100 is a client in this situation and is connecting to a TCP Server on my PC.
If that helps I can get some SPI capture so you can better see what is writing to W6100.
by mateusz ·
Ok I found it out! Thanks for the suggestion that the port is 0.
I tried to set 0x0114 to 14001 and now it opens.
Sadly that isn’t mention in the documentation but important that it works now :).
