W5500 client-How to handle receiving large file
RE: W5500 client-How to handle receiving large file
by cellkey ·
Well, I made it…
I can get the file ok, very easy, I must say… Lot easier than I thought…
Thanks for participating and support…
Dan …
RE: RE: W5500 client-How to handle receiving large file
by Vien Huy Nguyen ·
Hi Dan,
Could you share the solution? Thank you.
by cellkey ·
Hi, that was long ago. Please remind me the subject and what you want to achieve…
Regards
Dan
by cellkey ·
Do you mean reading file text from server?
If so I have to return to the code and share the relevant part.
Dan
by cellkey ·
Do you have any experience with the WZ5500? do u work with it some how?
by cellkey ·
Well, I read your post about your problem. My code is to get a HEX file from my server which is used to update firmware of the host controller. This is about 50k bytes in size. I don’t yet understand your post stucture and the problems that you are facing with it…
Dan
Hi Dan,
Thank you for replying.
I wanted to receive a large file send to the W5500 by the mean of a HTTP POST request.
Did you modify the WIZnet’s httpServer library or did you write your own code from scratch to achieve your tasks?
by cellkey ·
Hi, i have not changed any thing in libraries. My server knew to get a request to send a file which was uploaded to it in advance. The code send to sever a request message (my own protocol) and get into receiving loop in which it get file (about 50K bytes) in several reading interactions to a local memory.
I can organize the relevant code and send it to you but it will take one or two days…
Is that ok?
Dan
by cellkey ·
Hi, Attaching ZIP with few files for your inspection. The C file has the main proc RxUpdateFile which do the job. Try to understand the mechanism and if you still have questions ask me.
I added my own receiving proc to socket.c file.
Good luck
Dan
WZ5500_LAN_FileReceiv.ZIP (33.8 KB)
Thanks Dan. I really appreciate it.
