WizFi360 MQTT?
RE: WizFi360 MQTT?
by viktor WIZnet ·
Dear Nikita,
Thanks for using our products.
Regarding MQTT, when you make settings for MQTT TOPIC, you can setup 1 publish topic and 3 subscribe topics for WizFi360. Please refer to MQTT commands instructions guide (https://wizwiki.net/wiki/lib/exe/fetch.php/products:wizfi360:wizfi360ds:wizfi360_atset_v107.2e.pdf)
In order to setup topic again, you need to disconnect with broker first.
Best regards,
Viktor
RE: RE: WizFi360 MQTT?
by nikita ·
Доброе утро.
Спасибо за ответ.
Тем не менее не понимаю логики такой реализации.
Получается с использование WizFi360 можно разве что включать/выключать лампочку и снимать данные с пары датчиков.
Зачем надо было так ограничивать возможности MQTT протокола?
Почему бы не сделать MQTT как у WizFi310?
Тем более такой подход не требует большого расхода по памяти программы, да и оперативной памяти тоже.
Good morning.
Thanks for the answer.
Nevertheless, I do not understand the logic of such an implementation.
It turns out using WizFi360 can only turn on / off the bulb and take data from a pair of sensors.
Why was it necessary to limit the capabilities of the MQTT protocol?
Why not make MQTT like the WizFi310?
Moreover, this approach does not require a large consumption of program memory, and RAM, too.
RE: WizFi360 MQTT?
by viktor WIZnet ·
Dear Nikita,
I will forward your proposal to developers team and ask them to consider this during next firmware release.
Have a great day.
Best regards,
Viktor
by nikita ·
Hello, Viktor,
I will be excited to wait for a new firmware.
Many thanks.
You are best!
