W5100 SPI Mode Problem
RE: W5100 SPI Mode Problem
by Daniel Oliveira ·
Another example of the SPI communication ouput. Read frames are missing a byte and some operations are receiving wrong values.
RE: RE: W5100 SPI Mode Problem
by bangbh ·
Yeah, you’re right.
There must be a problem with the SPI read function.
As you said, your MCU makes the CS line high before reading something.
Please look at the SPI read part again.
Hi again,
I solved this issue by forcing a read byte for each write byte. Thanks.
