W5100S - MACRAW mode doesn't work
RE: W5100S - MACRAW mode doesn't work
Hi~ rogerthat
Could you please try to test the loopback TCP?
I will try to test as MACRAW.
I will tell you the test results as soon as possible.
Best regards
irina
by rogerthat ·
Hello Irina,
First good news: I tried TCP loop-back test and the result was a SUCCESS with both chip variants.
Then, I started debugging the whole library code.
It seems to me there is a problem around the code snippet socket.c → recvfrom(…) → case Sn_MR_MACRAW: .
Somehow the condition if(sock_remained_size[sn] > 1514) becomes true and socket is closed.
Note: I also sometimes observe that (head[0]+head[1]) equals 0 and then 2 is subtracted, which results in a huge number (i.e., 0 - 2 = 0xFFFE).
I searched this forum about similar problems and have seen some issues with other chips in the past where some kind of overflow is involved. I suppose those problems already belong to the past and current library code must be fully tested and functional.
Hope you come back with some good news upon finishing your MACRAW test!
PS: There may also be a minor copy-paste error in function wizchip_conf.c → wizchip_init()
while((rxsize[i] >> j != 1)&&(txsize[i] !=0)){j++;}
But this is not responsible for my situation.
