Issue with W5500 hardware interrupt
RE: Issue with W5500 hardware interrupt
I recommend you set Sn_IMR to 0x04. If so, the interrupt occurs only when it is recv, so there is no need to check if it is a recv interrupt when the interrupt occurs.
setSIR (0x00) is meaningless. SIR is automatically cleared according to Sn_IR. If you did setSn_IR (SOCK_TCP, 0x1F), the interrupt is cleared and the INT line should go high. If setSn_IMR (0xff) is set and you set setSn_IR (SOCK_TCP, 0x1F) in recv only, interrupts may occur in other bits and thus may not be cleared. This can be solved by setting 0x04 in sn_imr.
RE: RE: Issue with W5500 hardware interrupt
by xshura ·
Thanks for your reply. Everything works fine now!
Do I understand correctly that I only need to reset the bit in the Sn_IR register that raised an interrupt?
by Deepak ·
How can I implement a callback function to receive incoming data ??
