WizNet5100 accepts connections on ANY TCP port, even when none are open
RE: WizNet5100 accepts connections on ANY TCP port, even when none are open
Could you please post your source code on the website?
Then I’ll check about it.
by WhizzBangGone ·
This is all you need to replicate the problem (using Arduino IDE):
You will notice that the EthernetServer line is commented out and there are no open ports. However if you connect to the interface using ANY TCP port number using a terminal program such as e.g. PuTTY, it will open a terminal window instead of rejecting the connection.
The problem has been confirmed by at least one other person. They were able to test with both a W5100 and W5500 and only the W5100 had the problem.
RE: RE: WizNet5100 accepts connections on ANY TCP port, even when none are open
I’m sorry for late reply.
I think we or you need to check the Ethernet library in Arduino IDE.
Because this issue didn’t occur in the io-library code we provide,it is for embedded user.
by WhizzBangGone ·
Thank you for getting back to me. I did raise the issue on the Arduino Ethernet library GitHub. I did get an acknowledgement from another user who confirmed they had the same problem. It is interesting to note that another library does not behave the same way. I will pass this information back into the GitHub case.
