could not able to open socket
RE: could not able to open socket
by Mxyxixptlick ·
Try configuring your IP address, gateway & subnet AFTER resetting the chip rather than before. Sending the reset command (setMR(MR_RST)) resets all registers to default values, undoing your configuration.
by Yogesh ·
Thank You for your reply,
I have corrected my code as per your suggestion but still i am facing the same problem.
I would like to inform you that I am using w5500.h and w5500.c from standard IO library prescribed by wiznet.io,(GitHub - Wiznet/ioLibrary_Driver: ioLibrary_Driver can be used for the application design of WIZnet TCP/IP chips as W5500, W5300, W5200, W5100 W5100S.).
by Yogesh ·
@midnightcow,
Thanks for the response.
I have used sendto() func as you said but still it is not working. please find my code below.
by Yogesh ·
@midnightcow
Thanks for the reply.
I am using Nucleo STM32F103RB development board and w5100 Ethernet shield .
STMcubeMX & Atollic true studio for coding ,also I am using wireshark tool to monitor the data.
Hardware configuration in Nucleo board.
1.Peripheral: SPI2
2.Pins : PB13,PB14,PB15 & PB12
3.Baud_rate: 18MBits/sec.
The code which i have got from following link is modified for my board and it is working for TCP, but the same code is modified for UDP it is not working which i already shared with you.
Please find the link below.
by Yogesh ·
I have shared data packets captured from wireshark tool, also i changed Gateway IP value but still not working.
Thank you,
