W3150A+ UDP receive issue
RE: W3150A+ UDP receive issue
by dkay ·
Hi, btprg.
First, test that your interface is collect. Reading version register many times or writing & reading some registers which are available to read&write
I recommend that you read RX_RSR twice. If each value is same, try to read receive buffer data.
For example,
If problem is not resolved, please contact us again.
And if you can open your code, please share it.
by btprg ·
Hi dkay,
The random register read/write operations work normally.
My original code was this:
Before reading your message, I implemented a version that uses the UDP header size parameter (as the datasheet suggests) if the RX_RSR value is smaller than it. This works fine.
Then I implemented the multiple RX_RSR reading suggested by you, and it also works well.
So my problem is solved, thank you
But I am wondering what is the reason of this thing that RX_RSR sometimes contains too small number…
If you are interested, I could send the whole driver. It only supports UDP, but it is much less complicated than the example driver provided by WIZnet.
Best wishes.
