LED Not active
RE: LED Not active
Would 1k resistors provide enough current for the LEDs to be lit?
Why 50 Ohms instead of required 49.9 1% Ohms? Are they 1%?
Why 6.8 picofarads instead of 6.8 nanofarads?
What “ferrite” is used here?
Is chip accessible through SPI?
RE: LED Not active
by scott WIZnet ·
@kiazoo
Your capacitor is wrong.
6.8pF → 6.8nF
If we can fix this and the problem continues,
Your symptoms are caused by improper PCB design.
Did you refer to the design guide at the URL below?
https://wizwiki.net/wiki/doku.php/design_guide:hardware:start
RE: LED Not active
by kiazoo ·
Thank for all reply.
this case my MCU can access the W5500 chip. i use same controller and wire to W5500 module (i got it from alibaba) it 's work.
In circuit ferrite is 33Ohm. i use 50Ohm resistor because it’s best i can find in my local seller.
but capacitor is my wrong i will fix it first.
