TCP client problems.
RE: TCP client problems.
Most probably the client sends RST because its socket is closed when it receives TCP packet.
Seems you did not get any material answer on your last topic; you must provide more information to get through. What do all the common registers have in them, and this socket registers when SR is read as 0x03? We are looking for the register value corruption now. This hypothesis partially confirms RST message as something wrong happens with socket in overall (or with chip configuration at all), and it must be verified.
So we have confirmation what there’s misconfiguration of the chip. This condition can happen in the following cases:
In the current situation the best way is to check if you use correct registers to write to, do not confuse pointers with values, and perform logging of every register write so that write sequence can be analyzed.
