TCP connection only possible with a 2-4 sec delay between init and socket programming
IO Modules
IO Modules
RE: TCP connection only possible with a 2-4 sec delay between init and socket programming
I think you have to fix it such as below:
while(!(getPHYCFGR() & PHYCFGR_LNK_ON));
RE: RE: TCP connection only possible with a 2-4 sec delay between init and socket programming
by Caspar ·
Hi Becky,
Yes you are right, that’s a mistake in my code. Thank you for noticing, i changed it in my code. Unfortunately this is not the solution to my problem. The module still fails to connect with the server without that 3-4 second delay. So i’m curious if there is another factor which plays a part in the initialization of the module.
Caspar
In the first packet, the W5500 sent an arp request. But belkin did not give an arp response. If the w5500 does not receive an arp response, it retransmits every 200ms. However, no retransmission is seen in the first packet.
I think there are two cases.
The first is that there was more arp transmission before, but it was not visible because it was sent before link up.
The second is that the phy link is unstable.
It is recommended to check the phy twice by modifying as follows to ensure the stability of phy
while (1) {
check1 = getPHYCFGR () & PHYCFGR_LNK_ON
check2 = getPHYCFGR () & PHYCFGR_LNK_ON
if (check == 0x01 && check2 == 0x01) break;
by Caspar ·
The suggestion of polling the phy link twice worked. Thank you
