WSET and WSEC not being saved
RE: WSET and WSEC not being saved
by wizdaniel ·
Hi
Most of configurations can be stored in Flash drive with +MPROF=S.
but, the commands regarding Network attachment, such as +WSET, +WNET, +WSEC, can be stored in Flash drive directly when you type that commands without +MPROF=S.
you should type +MPROF=S commands to store configuration. if you want to store some configurations like module config, auto connection and so on.
which commands did you lost?
RE: RE: WSET and WSEC not being saved
by Luis Villegas ·
Hey there,
thanks for the follow, those commands that i was talking about, were precisaly wset, wnet and wsec, they are not being stored, when i called them. I checked this by set them up, and then resetting the module, it will always start with the default configurations.
So, what i think is that every configuration must be stored by using MPROF=S, the datasheet is wrong about the commands that states “autosaving”
by wizdaniel ·
thanks, I will check about that
