Can I use 3.3v output of w7500 to control 8-channel relay boards developed for arduino 5v otput?
RE: Can I use 3.3v output of w7500 to control 8-channel relay boards developed for arduino 5v otput?
Hi~ Yegors
I’m so sorry about getting back to you so late.
First, I think you use the 3.3v and 5v as output voltage using the wizwiki-7500.
See J13 on the wizwki-w7500, you can see the 3.3v and 5v pin.
And I don’t know what “optocuper” is. I think it’s like the LED or something, is it right?
Tell me more about the optocuper.
thanks,
BR
by YegorS ·
Hello Irina Kim
by YegorS ·
Hi
I am new in mbed and microcontrollers programming.
On the different forums I found solution - how to connect more then 3.3v devices directly to microcontroller: need to
It lets to control devices which use more then 3.3v, for example 12v. Disabling the resistor prevents the board from burning out.
My questions is:
Example of code:
https://os.mbed.com/teams/TVZ-Mechatronics-Team/wiki/Digital-inputs-and-outputs
https://community.st.com/s/question/0D50X00009XkXlk/can-5-v-tolerant-pin-be-turned-off
