No link and not SPI comms
RE: No link and not SPI comms
Check two things: powers (3.3V and 1.2V), and crystal clocking at correct frequency.
What is it?
Must be either design fault, or some bad/incorrect component.
by syvic ·
Thanks for your help.
The powers seems to be OK. (3.36V at the output of the regulator and 1.25V on pin 22 (1V20)
I don’t know why I have that signal on pin 36 (INT). Here’s a capture from the oscilloscope:
About the crystal signals looks fine: First one is XI and the second one is XO:
We had to change de crystal to a new that fits better with the w5500. The original gave us some ugly signals… Could have the old crystal broke the w5500?
Here I have a capture from the logic analyzer, in case it helps:
Thanks again for your help.
RE: RE: No link and not SPI comms
Most probably not. Try removing pull-up resistors from RSVD pins. Not sure why you have them as they create 2.95V through built-in pull-downs of 85k.
by syvic ·
We just left the RSVD signals disconnected (pins 38 to 42) and we have made some progress:
Now when booting without Ethernet cable connected the two LEDs (ACT and LINK) are off.
If we connect an Ethernet cable the LINK LED stays off, although now, for the first time, the computer does recognize LINK. In fact, if we ping or generate any type of traffic, the ACT LED already lights up.
However, we still have no response in the MISO line.
Any other suggestions?
Ensure you use correct cable.
by syvic ·
We have tried to make the same change (remove the resistors that we had in RSVD) in the rest of the PCBs and it seems that they work correctly. For some reason the PCB to which we changed the crystal does not work well, but we will investigate.
Thank you very much for your help!
