HTTP STRING from AT command via serial
IO Modules
IO Modules
RE: HTTP STRING from AT command via serial
by scott WIZnet ·
Hi Giuseppe,
Do you use WIZ550io?
Sorry, we do not have the example you want.
The feature you want is you have to implement it on your MCU yourself.
Scott
As scott mentioned, we do not have an example.
But it is very easy to implement what you said.
What firmware are you using?
If you are using iolibrary, try the following.
You have to modify it as I wrote it simply.
