TCP Server Socket with keep alive / No Timeout INT occurs when client is killed
RE: TCP Server Socket with keep alive / No Timeout INT occurs when client is killed
No, everything is correct.
Server waits for incoming packets, and it will be waiting forever until it will receive something - FIN, RST, or data.
You do it manually (0x22), or use keep-alive timer.
Datasheet says:
There will be no keep-alive (neither 0x22 nor automatic using timer) if there was no prior communication.
by oliver28 ·
Thank you for the information.
In fact the TCP server starts sending KEEP ALIVE packets first when a TX packet was transferred by the TCP Server.
RX packets witout response by the server will not start the KA process. (even if KA timer is set or CMD 0x22 is written to the Command Reg.)
I will resolve the detection of those dead connections in an other way. (no activity, after a defined timeout , send 1 Byte TX, this should start the KA process)
