W5500 Link Led will work sometime
RE: W5500 Link Led will work sometime
Post circuit diagram please. |Most probably you are having the issues with PHY circuitry, or with clock circuitry.
RE: RE: W5500 Link Led will work sometime
by Century ·
ETHERNET PDF.pdf (22.8 KB)
Seems to be exact copy of reference schematic, except R2 which must not make a difference. Don’t you accidentally have PHY disabled through PHYCFGR? Try playing with its contents to see if there’s any change.
by Century ·
I am always getting 10111010 response for PHYCFGR. That means it is configured correctly.
In circuit TX/RX resistor values are correct? I kept 33R instead of 0R.
LSB of 0 suggests that there’s really no physical link.
There were people changing 33 to 0, but if I recall properly it was not that bad as you describe. But anyway it is a good idea to change them to 0 (shorts) as a test. Also examine board with magnifier to ensure it has no assembly issues.
by Century ·
Ok, Thank you will try that.
by benjonson ·
Why my post is showing this error?
Please guide me and live my post.
