Can't connect with 100Mbit
RE: Can't connect with 100Mbit
There seem to be a mistake for PHYCR0 in datasheet as it says
and it is not clear if bit should be 0 or 1. I propose you to play with this bit, and not set PHYCR0’s bit 1 to 1.
by Daan ·
Thank you Eugeny, that was the trick! PHYCR0 bit 1 should not be set. Now it’s running at 100Mbit
