No ethernet connectivity
RE: No ethernet connectivity
How do you know that? LEDs, registers? If it is really the case, then you must have made mistake in your board, and “hardware side” is having trouble.
Did you make exact copy of reference design, or changed some components (e.g MagJack)?
Share your actual circuit diagram.
RE: RE: No ethernet connectivity
by lekkeband ·
Solved!! connector
We will appreciate if you can exmplain your solution (and elaborate on the issue) in more detail so that others having similar one can solve theirs.
