Network connection stability issue
RE: Network connection stability issue
You are not the first person experiencing issues with W5x00 + Cisco. Probably Cisco switches are too clever for W5x00, and you must make switch slightly dumber not to drive W5x00 crazy. I bet when your “instability” happens, W5100 continuously flashes its link LED (and also RX LED).
You have two things to try - one of them, or both must improve the situation, or solve your issue:
RE: RE: Network connection stability issue
by estech777 ·
We will ask the network administrator to apply your suggestion.
Thank you so much for your quick response.
