How does Sn_RX_RSR behave in case of overrun?
RE: How does Sn_RX_RSR behave in case of overrun?
Yes.
It can not receive more data, and it explicitly states it to the remote network device in specific field of TCP packet. You can not consider W5x00 socket programming in disconnection with the “other side” - data flow and protocol of the network.
RSR is indication how many bytes application can get from the buffer. Its range is 0 to buffer size.
W5x00 says remote device not to send anything until W5x00 has space to receive it.
For UDP and RAW modes, new data not fitting into buffer is discarded, thus it is in your application’s interests to flush data as fast as possible.
by sqjsXvnqH2JbsUeS ·
Again, thank you very much for your time and expertise!
Yes, silly me. I should have known better and should have asked for UDP. Nevertheless, I think your last statement from your post above answers all my questions:
This is reasonable and expected behavior. So Sn_RX_RSR is a saturated register (and not a wrap-around register):
When the RX buffer is full and new data arrives, the new arriving data is discarded, meaning that nothing in the buffer gets overwritten. This in turn means that the number of bytes we can read from the RX buffer remains constant, and this finally means that Sn_RX_RSR remains constant.
Thank you very much again!
