W5300 High-capacity data communication
RE: W5300 High-capacity data communication
Share wireshark log. “TCP zero window” will happen after receiving first 2k if you do not flush data from RX buffers.
by tnk ·
Thank you for the e-mail.
We incorporate W5300 in the receiver of the printer.
Below is the contents checked here.
Reading from R_FIFO is executed by DMA.
//SOCK_ESTABLISHED: Receive
if((len=getSn_RX_RSR(s)) > 0) // check the size of received data
// Test200M data
len = recv(s,ep3_rxdat,len); // Datalength Read
//DMA Dest set
HeadAdr = (unsigned long)&FIFOW_0;
//DMA
dma_EthFIFOtoEgnFIFO_eth(len/2);
*Wireshark Error
PC:192.168.0.10 W5300:192.1680.3
Overall data amount PC spool: 200 Mbytes
Error occurrence: Approximately 100 Mbytes
PC⇒zerowindowprob W5300:no replay
PC⇒RST
Why does W5300 not respond?
Thank you in advance.
The cause of the problem is not W5300, it is your PC. You continuously send one byte to PC from W5300, and PC does not read it from its RX queue. Screenshot shows that PC has window size 4, then 3, then 2, then 1, and finally 0, and next write from W5300 to PC goes nowhere, so PC resets the connection shortly as communication looks broken.
RE: RE: W5300 High-capacity data communication
by tnk ·
I will change the conditions such as PC and check it.
I will report the results.
by tnk ·
Hello.
I investigated PC window size.
os: window 7 98 M / 200 Mbytes received.
Initial value: 64200
Dummy data (ACK) from W 5300 1 byte Receive every -1
os: window 10 180 M / 200 Mbytes received.
It returns to the initial value on the way and then -1 after receiving the data.
I decided it was not a problem of W5300 but a problem of PC side.
I was rude in an unclear English sentence. (I am Japanese.)
Please also take a consultation.
by tnk ·
Dear Great Contributor.
I can’t change TCPiPapps in my PC
To fix PC Window size, I tried to 0bytes ack data from w5300.
Wiresharklog
175kbytes/200Mbytes
192.168.0.3(w5300) ZeroWindow
What is the purpose of dummy size transfer?
What is the difference between dummy size 0 and dummy size 1?
Why does zerowindow occur in dummy size 0 ?
Best regards
You can see in wireshark packet #43 that it reports W5300 window size as 0. The situation simply means that W5300 stopped getting data from its RX buffers. Check your program driving W5300.
What is this “dummy size”? Using TCP you do should not send anything if it is not required by protocol. Does your protocol require sending these bytes?
Because now it is W5300 which stops clearing its RX buffer.
by tnk ·
The following is the TX transfer size.
setSn_TX_WRSR(s,0); // size :0 byte dummy size
setSn_TX_WRSR(s,1); // size :1 byte dummy size
Best regards
by tnk ·
Dear Eugeny
Attached log is basic, flow and please tell me at the timing of a reply of ACK of W5300.
*Please tell me at the timing of a reply of No.11,13,15,17,19,21.
Best regards
Not sure what you want to know about this picture. It just shows that IP address 10 connects to IP address 3, sends some data and then closes connection, and IP address 3 confirms the end of session. There seem to be no issue in the communication. The only strange thing is IP address 3 having PSH flag set in its ACK packets.
by tnk ·
Dear Eugeny
IP address
