SSEND gap limits
RE: SSEND gap limits
Hi !
kzsolt2
→ You mean, how many data WizFi310 can send at once?
The tool that I use support 2047 bytes per line.
So, I tested WizFi250 acts as a TCP server(command mode) and sends to client 2047 bytes at ones. It works fine!
Regards,
Tom.
by kzsolt2 ·
Dear Tom!
Sorry no.
I use DMA for tramsmit.
If I copy AT+SSEND=…\r command and its data to one buffer and I send it with one DMA transfer, then it is works well.
But need few resource if I send command and its data separately.
For example:
AT+SSEND=…\r -DMA transfer-
-gap-
[ssend data] -DMA transfer-
But between two DMA transfer has gap (time).
This can be measured in bittime.
If this time is longer than 256? bit, then wizfi abort the transmission, and accept ssend data as command.
Best Regards, kzsolt2
