RX_RSR/RX_RD value is abnormal
RE: RX_RSR/RX_RD value is abnormal
Please share related Wireshark log.
RE: RE: RX_RSR/RX_RD value is abnormal
by ttc ·
Hi Eugeny, Thank you for your reply.
Attach the requested file.
The IP address of w5100 is 192.168.10.100.
Please filter with tcp.port == 2111.
Packets 47 to 268 are normal communication data.
Packets 1836 to 1955 are abnormal communication data.
Two of communication is using the same data.
In case of abnormality, large amounts of data are sent at once and can not be received.
Please say anything if you need more information.
Thanks for your help.
senderr.zip (84.1 KB)
I do not see [SYN, ACK] response from the W5100 which must follow [SYN].
I am not sure, but it may happen that you mess the RX pointer - for example just after connect you get RX pointer 0, received size of 2048. You copy 2048 bytes from buffer, and set RX_RD pointer to 2048. Then you receive 2048, get the new data, but for some reason update RX_RD not with 4096, but with 32347 (or some other wrong number out of the data you can get from the buffer).
I recommend you making log of the sizes you receive and pointers you update with. Note that RX_RD pointer is full 16 bit, and you must treat bits [15:12] properly.
by ttc ·
Hi Eugeny.
I got a log.
RSR and RD are register raw values.
Mask with 0x7FF when using.
On success, it is a multiple of 0x0400 except the last packet.
I think that 1631 of RD is 0x6000 of the sum of 1630 0x0400 of RSR and 1630 0x5c00 of RD, but it is actually different.
I think that the phenomenon pointed out is occurring, but how should I respond?
1631: RX_RSR can not be 24897 because RX buffer size is only 2K. Check register reading routine. Is this value displayed just after you read the register (maybe you perform some math operations modifying the value before displaying?)
Also RX_RD does not look proper - 23552+24897 does not equal to 65215.
Please post your receiving code.
Can you also perform dump of all registers - common and related socket registers - when you encounter RSR of > 2048?
by ttc ·
I will attach an excerpt code of the receiving part.
w5100 connected by a bus.
Yes, The last log is obtained by getSnRxRd, getSnRxRsr at the time of reception.
No operations, Direct register value.
I will try.
recv.zip (878 バイト)
If you would log direct value it would be big-endian. From your code I see there’re several move, AND and shift operations are applied. Log direct values read by
REGS[ sn ].RX_RSR.WORDandREGS[ sn ].RX_RD.WORD. Does your implementation read byte at offset +0 first, and then byte at offset +1, or vice versa?There’s no
setSnRxRd()andWAIT_ENDPROCESS()in the code.Elsecondition forif(0 < recLen)inrecv()is wrong - even if socket is closed at the time you read socket status, it does not mean that nothing was received into W5100 buffer after you last time checked for the RX_RSR being 0 and before status read. You must check for RSR being 0 once more, and flush remaining data of there’s any data.What is the value of
W5100_RX_BUFF_SIZE? According to comment, must be 0x800.So:
recvin its else condition;RE: RX_RSR/RX_RD value is abnormal
by ttc ·
Log value is
0x0426 0x0427
0x08 0x00
I am reading it as shown in W5100 Datasheet V1.2.7 Page.36.
getRxRsr and getRxRd return the calculated value.
sorry. It was missing last time. So added this time.
I get dump.Please confirm the attached file.
receive error is occurring at socket4.
I checked again and added a bit of correction.
data.zip (8.1 KB)
I can not open BIN file. It should be text file with readable values of the registers.
I have better suggestion: replace
if ((status == Sn_SR_LISTEN) || (status == Sn_SR_CLOSED) || (status == Sn_SR_CLOSE_WAIT))with just
if (status != Sn_SR_ESTABLISHED)as chip will normally receive data only when connection is established. There’s small exception though - when remote device has sent FIN packet, SR will change to SOCK_CLOSE_WAIT, and then your
recvfunction will return 0 (however W5100 is still allowed to send data).RE: RX_RSR/RX_RD value is abnormal
by ttc ·
Thank you, problem is solved.
The cause was a simple mistake.
When observing RX_RD carefully, we rarely set unintended values.
The reason was that I used one rxPtr with 4 sockets.
during reception of socket 4, interrupt reception of socket1(higher priority) occur,
rxPtr is unintended values.
So I fixed it as follows.
This correction no longer causes abnormal RX_RD values.
Thank you for much cooperation.
