Wiz750sr-rs232 interface silab 8051 rs232
RE: Wiz750sr-rs232 interface silab 8051 rs232
For the MCU, the WIZ750SR serial to Ethernet module is the same as the device connected to the UART peripheral. Once the network settings are set up properly, you can send and receive Ethernet data via the UART.
You can find the WIZ750SR user’s guide and Datasheet at the link below.
https://wizwiki.net/wiki/doku.php?id=products:wiz750sr:start
