I can`t load
RE: I can`t load
Hi, NKIM.
I suggest using the ‘Auto Task Selection’ and ‘Go’ button located at the bottom left.
Please check the steps 1 through 3 only.
(For the W7100A chip, the ‘Verify’ step is meaningless due to the specificity of the memory structure, such as lock bit)
After the serial connection of the ISP port,
please press the ‘Go’ button to perform the ISP process.
