Issue at Interfacing W5300 with W5100
RE: Issue at Interfacing W5300 with W5100
This value sounds to be invalid for Sn_IR; three MSBs must be zeros. You may be reading incorrect register from the chip, or reading the register incorrectly.
Or you really read IR register (at address 0x15)?
Should be correct behavior.
Where do you check these receive bits? At “server” (W5300) side?
