A sample loopback program for W5200E0l, which uses eth loopback plug
RE: A sample loopback program for W5200E0l, which uses eth loopback plug
by lawrence WIZnet ·
Hello karthik-altran
Here is the link about W5200 datasheet and application program
http://www.wiznet.io/product-item/w5200/
And refer this ioLibrary for the loopback program. In Internet application, you can refer the loopback.
https://github.com/Wiznet/ioLibrary_Driver
RE: RE: A sample loopback program for W5200E0l, which uses eth loopback plug
by karthik-altran ·
Hello Lawrence,
Thanks for you reply, software provided by wiznet has a loopback program but it works only with an
AXI application which has to be installed in a different PC, W5200E01 and the PC has to be connected with ethernet cable, but my requirement is different thatis the program running in wE200E01 has to perform loopback test just by connecting a loopback plug in RJ45 of w5200 and not with the help of a external PC, kindly help me in this.
Regards,
Karthik
You can make this program yourself using libraries provided by WIZnet and pointed by @lawrence. The libraries allow you to configure the chip, to send data, and to receive it.
It is not clear what is the purpose of “solution” you ask for. Loopback as is does not have much usefulness, it is rather test which you do not perform in the field during normal device operation.
