High temperature and high consumption
RE: High temperature and high consumption
Let’s start with considering circuit diagram of your device, and set of components you use. Can you please share actual circuit diagram, and pictures of the board from both sides with areas related to the W5500 chip?
by Jan ·
by Jan ·
by Jan ·
RE: RE: High temperature and high consumption
I do not see immediately anything wrong with the circuit diagram or board layout. As you noted the issue happens to PHY, while digital core continues functioning properly (event @ 100 C). I assume your +3V3 power level is stable and within spec for the chip. I recall people talking about removing damping resistors and replacing them with 0R values (=shorting their pads). Try doing so, and let us know.
by Jan ·
Hi Eugeny, thank you for looking at schematic and board layout.
DC/DC converter with TPS560200 is stable. Its feature is current limiting at minimum 550mA but i checked it on devices in bad state and current limit is in range 750mA to 800mA (without powering the W5500). At normal power condition (current 0 to 700mA) the converter output noise is low (less than 50mVp-p).
A few weeks ago I tested devices in temperature chamber, because I was looking for the cause of the bad state. Device was tested in ambient temperature range -30 to +75 C. The test result is, that the cause of bad state is independent of temperature but…
When the device works at low teperature (bellow +10 C) then there is increased error rate at LAN link. The tests showed that solution to suppressing a LAN error is to reduce the damping resistors value to 0R.
It is one of the valuable insights for others
Devices usually work at room ambient temperature but for the next series of devices I’m going to change the damping resistors value to 0R (this is only a precautionary measure for me).
Now I can test if the change on damping rezistors takes some result with bad state.
Perhaps the combination of a 10 Mb / half duplex reduction, a more careful initialization, and now also a reduction in resistors value, will minimize bad states.
I am afraid of the fact that the W5500 chip can not be restarted from bad state in any way other than by turning off the power.
by Jan ·
I have one more note with the W5500.
If I touch simple any of pins 38 to 42 (RSVD pins) with the tweezer tip (which I hold with my hand) then the W5500 will go through the reset. (Maybe some kind of soft ESD?)
Is this a normal for W5500 or abnormal? Can anyone confirm this experience?
However, even in this way, I did not succeed in provoking the bad state (I tryied it many times).
Good catch, I missed it. You seems do not have pin 23 connected to ground as datasheet asks on page 10. Interesting that reference schematic is having this pins floating too.
by Jan ·
I forgot say - pin 23 I checked too by touches (all of pins of W5500). There is not sensitivity to touch (like 38 - 42).
by szokee ·
I had the same exact problem as you, and in my case it seemed to be caused by having spikes between GND and GNDA, for example when i attach external powered circuitry to mine. I’ve solved it by removing the ferrite bead between the two, basically eliminating GNDA. The problem never appeared since.
szokee
by Jan ·
I made the same discovery.
voltage spikes (ESD transitions) between AGND and GND are responsible for bad state of W5500. On the one hand, both spikes coming from the power source side and spikes (ESD) coming from the shield of the RJ45 connector. In my design, simply replacing the ground ferrite bead with short circuit was not enough. To remove the sensitivity to all overvoltage spikes, I had to add extra two tin bridges to the PCB (between GND and AGND).
The W5500 is somewhat more sensitive to ESD (maybe only between AGND and GND - ?). Therefore, I think that when designing a circuit with W5500, it is necessary to stick to the principle of not separating AGND from GND using a ferrite bead.
My circuit design and PCB were inspired by the WIZ850io and the W5500 reference design from Wizwiki.
I am quite convinced that if anybody brings a voltage of approx. + 30V to the WI850io module to RJ45 shield against the GND –> then the shield connects to the GND (it causes discharging the capacitor 1nF in the module (reference C9 in the WIZ850io diagram)) –> then this causes a bad state of W5500.
In my design, this is completely repeatable. And I do not see why this should not apply to the WIZ850io …
In any case, these are W5500 design recommendations:
The third recommendation depends on someone will succeed to get the W5500 from the bad state to a good state without switching off/on the power. Unfortunately, I think it’s impossible.
Jan
by scott WIZnet ·
Hello.
Your symptoms seem strange.
Resetting the W5500 will reset the internal TCP core and PHY. Return to normal.
With this in mind, it seems to be a problem with the MDI signal on your board.
To use the W5500 normally, TCT and RCT of RJ45 should be connected to each other.
https://wizwiki.net/wiki/lib/exe/fetch.php?media=wiznet_schematic:ethernet_chip:w5500_sch_v110_use_trans_.pdf
Your circuit is connected to 3.3V RCT. This can be a problem because excessive voltage is input to RX. This is a simple doubt.
We are not tested. We will test this.
by E Molina ·
I have implemented these suggestions and transferred the daughter board into my design, which is a 6 layer board. The following is what I did:
These changes yielded significant improvements. The ethernet would lock if i was to hit my system with Contact ESD of 500V, after all these changes i was able to hit the system with 8kV contact without the ethernet failing. I still have some issues with EFT’s of 2kV but with the added ON/OFF switch i am able to recover. I was able to pass my system for IEC 60601-1-2 for laboratory grade equipment.
I have yet to implement the recommendation of the 33R resistor maybe this will have an impact in my EFT test. I will post an update when i test that sometime next year.
by Infoetak ·
Hello to all!
Jan, it’s been a while since last post. Hope, You are still on-line…
Recently, I fell into same problems with wiz850io modules as You did 2 years ago.
What was Your final decission? Do You still use w5500? Any solution?
What did you mean by “I had to add extra two tin bridges to the PCB (between GND and AGND)”?
I’m realy looking foreward to hearing from You!
Best regards
Andrej
