MACRAW and IP sockets at the same time
RE: MACRAW and IP sockets at the same time
by jim ·
I will check W5100 case. But it will take time.
I will feedback after test.
I have one question.
Which interface do you try to use between host and W5100? Is it SPI?
RE: RE: MACRAW and IP sockets at the same time
No, device uses parallel interface with about 80 ns access cycle.
by jim ·
Do you use the bus interface?
Direct.
by lawrence WIZnet ·
Hello, Eugeny
Every socket can not receive when the RX buffer is full.
And it is ok to use SOCKET 0 as MACRAW and others as TCP or UDP.
W5100 checks socket exist and port number for TCP and UDP.
If there is correct socket having port number and IP, W5100 uploads packet to exact socket, not only SOCKET 0.
If w5100 works differently, please let us know.
lawrence
by jim ·
I tested MACRAW in W5100E01-AVR board on direct mode.
Socket 0 was used as MACRAW.
Socket 1~3 was used as TCP loopback.
All sockets were worked.
I think there is no problem to use MACRAW in W5100.
