Open TCP Port Not Recognized By Router
RE: Open TCP Port Not Recognized By Router
As long as you were talking to support, you most probably have much more technical information about the incident. Can you share it please? Did you investigate packets and their flow?
RE: RE: Open TCP Port Not Recognized By Router
by jim ·
Please check steps below.
If you don’t use DHCP in a target, change to DHCP.
And then check the status of target in a router.
After No. 1, if a target isn’t recognized in a router, you must have the connection of TCP between a target to external IP once. In this case, it doesn’t matter DHCP or Static IP. Please check the status of target in a router.
After No.2, if you can recognize a target in a router, and then please use port forward function in a router.
In my case, I used a WIZ550SR-EVB and ipTIME-A2004plus router. I succeeded.
