Easy/fast ethernet connection
RE: Easy/fast ethernet connection
This is design question, and it is hard to tell you what is the best in your situation.
What you describe is of course doable, easiness depends on your skills and knowledge.
Yes you link boards through SPI, and drive W5500 using your FPGA. Here you must understand that in FPGA you will need to implement SPI master circuitry, and higher level application-like circuitry to support W5500 function, in other words program which would perform W5500 programming and communication through SPI.
I am sorry it is unclear.
RE: RE: Easy/fast ethernet connection
by Vermu ·
What I meant is, to debug (see if the whole thing is working), I’ll connect my board to my computer and with a terminal (I don’t know if it’s the word in english) I’ll check which are the data my board is sending.
Is that more clear or not?
No, not clear how you connect it (serial port? LAN?) and which data you are expected to see (whole packets? only data?) I do not think it matters much, you only need to ensure that you will be able to make your desired configuration.
by Vermu ·
Since the W5500io got a RJ45 output, I’ll do a LAN between the PC and the board.
Only the data is interesting here (what comes from the FPGA and is sent again by the W5500)
Ok, so you know how to do it, then proceed designing FPGA configuration to support W5500, and also study W5500’s datasheet. The amount of your efforts will also be defined which programming level you choose - there’re W5x00 libraries for specific platforms available, see if you can reuse them in your device.
by Vermu ·
by ALRICH DSOUZA ·
WizNet Team,
We have purchased the W5500-EVB board for an Ethernet based project. We are planning to interface FPGA(Spartan 3 or Spartan 6) with an Ethernet(W5500) module. We want to display some sensor based data on web from FPGA and from webpage to FPGA for further processing. After completing the project we want to buy more W5500 modules to develop a network of sensor nodes.
The major requirement is interfacing an FPGA board with the W5500-EVB. I need to send the FPGA output data over Ethernet as an HTTP webpage.
Kindly provide us with your support on this and suggest some ideas to deal with the project. Please send this email to the concerned person with whom I can interact.
Thanks & Regards
Dsouza Alrich Xavier
Student- Electronics and Telecommunication Engineering
Mobile: 9137648124
Email: 2020.alrich.dsouza@ves.ac.in
by Gokul ·
Hi Alrich,
Have you got any solution? Any guidance would be much appreciable!!
