W7500 TCP client Example
RE: W7500 TCP client Example
by lawrence WIZnet ·
Hello, joaopaulob
Are you using W7500 with TCP client?
You only can send data in TCP after tcp connection success.
That is why it is hard to guess the network timing, with delay.
So, w7500 supports useful register, Sn_SR(sn), which can check network conditions.
With Sn_SR(n),
You can find the Sn_SR & Sn_RX_RSR in W7500 reference sheet.
http://wizwiki.net/wiki/lib/exe/fetch.php?media=products:w7500:w7500_rm_v109.pdf
lawrence
RE: RE: W7500 TCP client Example
by joaopaulob ·
I found the problem. The socket.c was set as non_blocking mode. The “Sn_SR(sn) != SOCK_ESTABLISHED” was not checked.
Thanks
You did !!
I am glad to hear that!
Thank you for your interests.
Feel free to ask anytime.
lawrence
