[TCP Send Error] explanation?
RE: [TCP Send Error] explanation?
by cliff ·
I’m so sorry for late reply.
If [TCP Send Error] message occurs, it is expected that it occurs because ACK is not received due to timeout in receiving ACK after TCP send.
“TCP send error timeout” is set to 5seconds by defualt.
The following is AT Command “AT+FSOCK” related to this case.
[url]http://wizwiki.net/wiki/doku.php?id=products:wizfi250:wizfi250pg:start#at_fsock[/url]
Check it and make sure that “AT + FSOCK = 1,0” works well.
For your information, “AT+FSOCK=1,0” is function that wait until you receive ACK.
Thanks, regards.
by phil31 ·
so what do i need to do when i receive this message ?
just restart the whole process to send again the same documents/data ?
does it closed or modify anything in the TCP socket server ?
thanks, regards
by cliff ·
That command is just change the socket setting, so please reopen socket.
Best regards.
