W5500: maximum parallel requests from same client
RE: W5500: maximum parallel requests from same client
As a follow up to the solution provided @stm32duino.com.
I was writing server for W5100 which has only 4 sockets. All 4 sockets were used at the same time, but if browser concurrently tries additional connection, it is refused. I even opened thread on Chrome support, did not help much. Thus I stuck to using Firefox as you do. For tuning it see here rs.gr8bit.ru/Documentation/GR8NET-manual.pdf section “MSX server”. In other words - do not use Google Chrome, it is not tunable and opens persistent connections which occupy sockets, but do not use them, for the time enough for other client/request to fail (average time of open socket is about 10 seconds).
by stevestrong ·
@Eugeny,
nice project.
I am thinking on changing the Ethernet lib so that 4 sockets shall be listening at a time instead of only one in the current version (although 8 sockets available), and see whether the processing of simultaneous requests will be improved or not.
