Set lan speed with 10M problem
RE: Set lan speed with 10M problem
by Wisse ·
I use mdio_write to change the speed:
Also be sure the mii link is correct!! phy_id does a check if return data is not 0, but forgets to check if data == 0xFFFF
For me this solved a lot of problems.
by k8051 ·
Thank you Wisse reply.
I solved the problem with Wisse suggests.
Thank you!
