W5500 polled TCP receive
RE: W5500 polled TCP receive
by Candela12 ·
While the number of bytes in the incoming buffer is the total, you can find out the number of parcels by parsing the data.
Each received packet has a header (IP, port and number of bytes), which you can use to find the individual packets, pseudo code:
done=0; while (done<totalInByte) { skip 6 bytes (IP and port) done=done+6; bytes=readword(buffer[done]); done=done+2; // process bytes bytes at buffer[done] done=done+bytes; }RE: W5500 polled TCP receive
by amb5l ·
I must confess that I’m coding without hardware just now so I’ve not been able to try this. I know the 8 byte information header is there with UDP packets but the documentation I’m looking at is not clear about TCP. If what you say works - fantastic - and thanks!
I will post when/if I get this working.
by Candela12 ·
I do mostly UDP nowadays, but I assumed the principle is the same. It might be that the exact header changes with sockettype though.
If you can’t find it in the W5500 datasheet, the manuals of the older parts (w5100,w5200) often have a more tutorial like character.
I will talk about TCP mode. There’s RAW mode, which I never used myself, which, as declared, should have info you are looking for.
Chip will receive all packets which fit into its socket’s buffer.
Yes.
RECV command instructs W5500 to check free space in the buffer (RX_RSR), and request remote host to send next packet in sequence (I simplify things a bit); if then sent packets fit buffer W5500 stores them, if not, discards until it has enough space. Thus you need to issue RECV command only once you freed space in the RX buffer.
In TCP mode - no, it provides stream of data only. Try RAW mode.
