TCP send problem with direct connection to PC
RE: TCP send problem with direct connection to PC
by MOHOMAX ·
And I just noticed that with some ethernet cables everything is working well. But I can’t see difference in cables: all of them are cat5, all of them have the same connnection scheme
by lawrence WIZnet ·
hello, MOHOMAX
Thank you for your interest in W5500.
So sorry, I could not find any other problem with etherner cable so far.
I wish you try to connect other PC or check it the cable normally working.
W5500 supports auto negotiation . So, It is hard to find any issues with cat5.
thank you
lawrence
by Candela12 ·
maybe turn automdi off on the adapter?
by MOHOMAX ·
I already tried a lot of different cables and connection variants. I tried different W5500 boards so it can’t be board defect (if schematic done right).
I have 3 PC to test my board:
All of them have Linux installed. I also have ethernet switch MOXA EDS-205
To connect our W5500 board I use two pairs cable. 4 pairs cable also was tested.
If I put ethernet switch between W5500 and any PC - works fine all the time.
I tried to disable automdi - didn’t help.
by MOHOMAX ·
We found the problem. Problem was in Rx and Tx pull-up resistors: instead of 49.9 Ohm resistors 49.9K were installed.
RE: RE: TCP send problem with direct connection to PC
Good to hear that!!
If there are any questions, please feel free to ask!
