Arduino Zero w/ W5500
RE: Arduino Zero w/ W5500
by StephenP ·
Arduino: 1.6.12 (Windows 8.1), Board: “Arduino/Genuino Zero (Programming Port)”
Build options changed, rebuilding all
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp: In member function ‘void W5500Class::init()’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:29:19: error: no matching function for call to ‘SPIClass::begin(int)’
SPI.begin(SPI_CS);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:29:19: note: candidate is:
In file included from C:\Program Files (x86)\Arduino\libraries\Ethernet\src/utility/w5100.h:13:0,
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:110:8: note: void SPIClass::begin()
void begin();
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:110:8: note: candidate expects 0 arguments, 1 provided
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:34:32: error: no matching function for call to ‘SPIClass::setClockDivider(int, int)’
SPI.setClockDivider(SPI_CS, 2); // 42 Mhz, ok
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:34:32: note: candidate is:
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:115:8: note: void SPIClass::setClockDivider(uint8_t)
void setClockDivider(uint8_t uc_div);
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:115:8: note: candidate expects 1 argument, 2 provided
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:35:36: error: no matching function for call to ‘SPIClass::setDataMode(int, int)’
SPI.setDataMode(SPI_CS, SPI_MODE0);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:35:36: note: candidate is:
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:114:8: note: void SPIClass::setDataMode(uint8_t)
void setDataMode(uint8_t uc_mode);
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:114:8: note: candidate expects 1 argument, 2 provided
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp: In static member function ‘static uint8_t W5500Class::write(uint16_t, uint8_t, uint8_t)’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:116:36: error: ‘SPI_CONTINUE’ was not declared in this scope
SPI.transfer(SPI_CS, _addr >> 8, SPI_CONTINUE);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:119:29: error: invalid conversion from ‘int’ to ‘void*’ [-fpermissive]
SPI.transfer(SPI_CS, _data);
C:\Users\Michael\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.6\libraries\SPI/SPI.h:135:6: error: initializing argument 1 of ‘void SPIClass::transfer(void*, size_t)’ [-fpermissive]
void SPIClass::transfer(void *buf, size_t count)
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp: In static member function ‘static uint16_t W5500Class::write(uint16_t, uint8_t, const uint8_t*, uint16_t)’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:137:36: error: ‘SPI_CONTINUE’ was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:143:30: error: invalid conversion from ‘int’ to ‘void*’ [-fpermissive]
SPI.transfer(SPI_CS, _buf[i]);
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp: In static member function ‘static uint8_t W5500Class::read(uint16_t, uint8_t)’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:159:38: error: ‘SPI_CONTINUE’ was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:162:43: error: invalid conversion from ‘int’ to ‘void*’ [-fpermissive]
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:162:43: error: void value not ignored as it ought to be
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp: In static member function ‘static uint16_t W5500Class::read(uint16_t, uint8_t, uint8_t*, uint16_t)’:
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:180:38: error: ‘SPI_CONTINUE’ was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:186:42: error: invalid conversion from ‘int’ to ‘void*’ [-fpermissive]
C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5500.cpp:186:18: error: void value not ignored as it ought to be
exit status 1
Error compiling for board Arduino/Genuino Zero (Programming Port).
This report would have more information with
“Show verbose output during compilation”
option enabled in File → Preferences.
by StephenP ·
Found the solution to my problem. I just had to use the Ethernet2 library as it is compatible with the Arduino Zero but not Zero pro.
github.com/adafruit/Ethernet2.git
by pablove28 ·
Hi Stephen,
How did you get the arduino zero work with the ethernet2 lib? I tried using that library but i got the error message “Failed to configure Ethernet using DHCP”.
