Socket interrupt mast not working
RE: Socket interrupt mast not working
You seem do not understand what interrupt is. Interrupt is low level signal generated on the INT pin of the chip. It informs controlling device that W5500 is having state change - using hardware notification.
Socket interrupt register contains set of flags, which indicate W5500 state changes. If respective IMR bit it set, and IR bit sets, W5500 activates INT pin. If repsective IMR bit is reset, and respective IR bit sets, INT pin does not change its state and hardware interrupt does not occur.
by aiwobiezou ·
Because the hardware designer does not realy connect the INT pin, we are simply pooling it, which is still a good choice since using this method we actually merged ckecking of multiple events into one register reading. The key point is in our method, the socket interrupt mask will take effect only on overall interrupt register level.
by Coccoliso ·
you have to set SIR(Socket Interrupt) and SIMR(Socket Interrupt Mask) and then you can check Sn_IR(Socket n Interrupt) for checking interrupt event.
RE: RE: Socket interrupt mast not working
by araz ·
hi
also you have to set Sn_IMR for any of socket you use,too
