How to send HTTP request
RE: How to send HTTP request
by wizdaniel ·
Hi
WizFi210 is based on a TCP layer(as known as Transport layer in TCP/IP layer) connection device. so, WizFi210 is the object in charge of performing the actual connection to the other “TCP layer” device, as well as writing requests and reading responses.
But, “CURL” that you used command is a command line tool using URL syntax(Application Layer in TCP/IP layer)
So, You have to change the request CURL syntax to TCP stream syntax like below.
[quote]
<0x1b>S0
POST /api/v1.6/variables/5689f91b76254265137e8e13/values HTTP/1.1
Content-Type: application/json
Content-Length: 13
X-Auth-Token: ZFJSStMA07BL87bNQtG8IXSPw06y330OIw9ZgUz6xSM3EVxJmdZiHCZ605Dh
Host: things.ubidots.com
{“value”: 24}
<0x1b>E[/quote]
Please copy below text and send to server
