How can I connect AP having WPA2 Personal Security
RE: How can I connect AP having WPA2 Personal Security
by wizdaniel ·
Hi.
There is a command log that will be able to connect to the AP having WPA2.
[quote]at+ws=wizms1
BSSID SSID Channel Type RSSI Security
e8:fc:af:fd:a2:85, wizms1 , 09, INFRA , -56 , WPA2-PERSONAL
No.Of AP Found:1
[OK]
at+wd
[OK]
at+ndhcp=1
[OK]
at+wwpa=xxxxxxxx
[OK]
at+wa=wizms1
IP SubNet Gateway
192.168.1.179: 255.255.255.0: 192.168.1.1
[OK][/quote]
:: xxxxxxxx is my AP’s passphrase.
if you want to choose the security type. just add the at+wsec command before at+wa command.
n=0 : auto
n=1 : open
n=2 : WEP
n=4 : WPA-PSK
n=8 : WPA2-PSK(security type of your AP)
n=16: WPA2 Enterprise
by revanth932 ·
Thank You danial…
