Implementing FTP client on W5200
RE: Implementing FTP client on W5200
by Ricky ·
Hi. cthomas
I’m sorry to hear that your problem.
First, look out the firewall(Turn off the firewall).
Second, Try see the below information.
Have you looked at our ioLibraries([url]https://github.com/Wiznet/ioLibrary_Driver[/url])?
We provied /Internet/FTPClient application. it is tested al ftp (Now it has been upgraded. it has been provided by the al drive.[url]http://www.altools.co.kr/Download/ALDrive.aspx[/url]).
Third, try make a data connection to the Active mode.
Kind Regards,
Craig, hopefully you resolved the issue. Please refer here http://ipswitchft.force.com/kb/articles/FAQ/Error-425-Can-t-open-data-connection-1307565974920 - in general the same what Ricky says, but it also lists SSL implementation as possible issue. The issue actually may be (a) client can not reach server and server informs client that it does not get any client’s reaction within specified time (check ports on the network), or (b) client tries to access using wrong way (e.g. SSL issue). IMHO you can distinguish one case from another by assessing timeout you get 425 response back from the server: for case (a) will be “standard” timeout, for case “b” response should follow immediately.
