Migrate from Wiz610wi to WizFi220
RE: Migrate from Wiz610wi to WizFi220
by wizdaniel ·
Hi
I have tried to use the command that you typed.
And i faced with error like your case.
The problem is AT+NSET command.
A WizFi220 gives the IP to a client using DHCP when DHCPSRVR is set.
When a WizFi220 gives the IP, a WizFi220 gives WizFi220 IP + 1.
If you set the WizFi220 IP = 192.168.1.254 and DHCP Server enable.
Client get the IP = 192.168.1.255 using WizFi220 DHCP Server.
192.168.1.255 IP is a Broadcast IP. WizFi220 Socket gives you an error.
so, you have to change the WizFi220 IP except ~
. 254,~. 255.RE: Migrate from Wiz610wi to WizFi220
by Cellix ·
Hi Wizdaniel,
You were right. I fixed the issue just changing the IP to .1 before executing the DHCPSRVR command and the change it back to .254 after and it works!.
–Edit–
I found the issue. Nothing to do with the WizFi220 module.
My apologies.
Regards,
by wizdaniel ·
Hi cellix
I’m glad to hear that you fixed the issue.
I wish you success with your great application.
