W5200 Read/Write Error
RE: W5200 Read/Write Error
by mefickle ·
Giving this a bump because I’m on a bit of a time constraint. Thanks again!
I want to look wave of oscilloscope.
I think MCU is not followed W5200 SPI format.
by abes ·
I’d recommend checking the SPI setup. It sounds possible that your MCU is in slave mode, and is driving the MISO pin when the slave select goes low. If you have a resistor on the MISO line you can remove, or if you can lift one of the pins to create an open circuit, you can verify who is actually driving that line.
I’ve use SPI based Wiznet modules (I think the W5200) before with no problems, so if that’s not it, maybe you are missing a detail of the protocol.
by mefickle ·
So my issue was that I was operating in the wrong SPI Mode and outputting data on the wrong clock edge. Thanks for the help/suggestions!
