SPI not initializing
RE: SPI not initializing
by wizdaniel ·
Hello Andreas Achilleos.
You can drive the instruction through SPI interface same as UART instruction.
When “AT+MSPI” status is set to “2”, you don’t use SPI interface. Just use UART.
I guess it’s because AT+MSPI status was changed to “0” or WizFi250 is set to Factory default.
by soellicha ·
Hello Daniel,
[quote]AT+MSPI=,
: Choice of interface (Required)
If set 0, WizFi250 Will set the interface it received first. For example, If MCU sends UART signal to WizFi250, WizFi250 will be set as UART interface. On the other hand, If MCU send SPI signal to WizFi250, WizFi250 will be set as SPI interface.
Parameter Meaning
0 Auto(Default)
1 UART
2 SPI [/quote]
You said : [quote]When “AT+MSPI” status is set to “2”, you don’t use SPI interface. Just use UART[/quote]
What is the correct for SPI? AT+MSPI=1 OR AT+MSPI=2 ?
Thank you,
Best Regards
Andreas Achilleos
by wizdaniel ·
Hi Andreas Achilleos
It was my mistake. AT+MSPI=2 is the correct command for SPI interface.
Official document is the most accurate.
wizwiki.net/wiki/doku.php?id=pro … rt#at_mspi
by Leandro Gagliardi ·
I am the same problem. After configure SPI as main interface and use the command: AT+MSPI=?, I get 1.0 (UART interface). Are there another command to unlock the SPI?
Thanks,
Leandro
